1995 G20 unknown wire, where dose it go?
Old March 16th, 2021, 9:53 PM
Jacob18's Avatar
Default 1995 G20 unknown wire, where dose it go?
I have a 1995 G20 with the 4.3 V6 in it. I found this wire the other day, and have no idea where it goes or what it goes to, the only two things I know of on the van that don’t work are the power windows and the wipers, it comes out under the dash under where the AC and heat controls are. if anyone has any idea where this goes or what it goes to that would be a huge help! This is my first time posting on here I just bought this van for $500 and it was not running, but after a battery it runs great!
Old March 18th, 2021, 6:39 AM
William Kisselstein's Avatar
Looks like something that would plug into the steering column, maybe. Going to have to get in there and look for a plug with that shape and nothing attached to it.
Given the wipers run off the stalk on the column it could be that's what it's for and it plugs in somewhere on that.
Power windows are pretty simple in these. There is a cross-body harness under the dash that's an add-on, it plugs into a ground tab high up under the left side of the dash and into a hot terminal in the fuse block, and the rest runs out to each door. I would take a switch off and use a meter to check for power at the switch and diagnose from there.
ChevyJan
September 15th, 2018 4:55 PM
Cheryl1975
May 11th, 2017 11:47 AM
Edptune@aol.com
July 30th, 2015 5:01 PM
phantomgem
April 3rd, 2007 4:39 PM
Quick Reply: 1995 G20 unknown wire, where dose it go?
