Headlight and Coolant
Hello!
recebtly bought a 2007 Chevy Express 3500 Skoolie.
I have a couple of questions for you lot.
First, I noticed my high beam was out on my driver side front headlamp. I bought a new sealed unit and installed it, I have the same problem! Normal beam fine, high beam, none existent. Is this a fuse issue? Any ideas?
Also, photo attached. What is this pipe coming off the coolant reservoir? I’ve not noticed it before but it’s not attached to anything. Has it slipped or it it for emergency let off so the tank won’t explode?
Thanks in advance.
Thanks in advance.
try swapping the low and high beam relays. Yes check the fuses of course.
that hose is the overflow. It should lead straight down to the road
The relay seems to be for both sides high beam, no individual relay. And as one is so should the other? Or is that wrong? As per picture. Loose connection maybe?
mountainmanjoe (September 30th, 2023)
grab a multimeter or test light. See if you get 12V on both legs of fuse 44. There should be exposed metal test points on the tops of the fuses.
Rednucleus (December 20th, 2023)
PaulR68
Express & G-Series Vans
October 8th, 2018 11:08 PM
2005_express6.0
July 5th, 2013 12:49 PM
