ignition key problems
Old April 11th, 2021, 11:16 AM
51Tinkerer's Avatar
Default ignition key problems
Hi All, I bought this 2010 Extended Express 3500 to convert to travel van and do a cross country trip. I barely got into starting interior before have mechanical issues. New fuel pump, new right side front hub because of ABS and stabiltrack dash light indicators and now key ignition issues ! I experienced that sometimes the key would not return to run position after starting. So I would have to return manually. Then this time it quit after driving a short drive of ten feet. First attempt at restart nothing, second attempt didn't start strong as usual but managed to start and stay running. Got it home in the driveway, shut off then tried to restart nothing no crank! So I thought it was bad starter switch so I replaced it but nothing changed. No crank and no key return to run position!
Should the starter switch have a spring return right on the switch itself? Or is there a spring inside the loch cylinder?
Randall Kogelman
14
October 6th, 2016 12:09 PM
Trentjh
May 17th, 2014 8:41 PM
advcomps
Silverado & Fullsize Pick-ups
September 18th, 2013 10:22 AM
shuttleman505
December 5th, 2011 11:40 AM
Stoepified
April 1st, 2008 11:32 PM
Quick Reply: ignition key problems
