Steering lock-up & starting problems
Old August 29th, 2011, 7:54 PM
cabinet's Avatar
Default Steering lock-up & starting problems
My 2000 Express 3500 has been recently experiencing a steering lock problem. It seems that when I make a slow, sharp left turn, like into a parking spot, the steering locks up and will not allow me to straighten out the steering. It's like I only have the left 20% of the steering range. To I have turn the wheel all the way to the left, and try to see if the steering will go back to normal. Sometime I may have to try this proceedure two or three times befor it will resume normal steering, and sometines hear a 'clunk'. It only happens at low speed and on sharp left turns. I don't see any obstruction under the car so I am leaning towards a bad steering box. Has anyone experienced this problem or know what might cause it ??
The other recent problem is with starting. On occasion, when I turn the key to start, all I hear is a 'click'. I assume this is the relay under the hood. If I try to start it several times, eventually it will start right up. The battery seems strong. Could it be the relay ? Or the 'in-park' indicator on the steering shaft ?
Any help on these problems is very much appreciated, Thanks!
Old September 12th, 2011, 7:39 AM
cabinet's Avatar
I seemed to have fixed the starting problem by just cleaning off the battery terminals and the starter relay contacts under the hood. So far ... so good. Still wondering about the steering lock up problem.
Old September 12th, 2011, 10:57 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Cabinet,
I am glad that the issue is getting resolved and everything is good so far. Have you contacted a dealership about the steering locking up? Keep us updated.
Breanne
Chevrolet Customer Service
Old September 13th, 2011, 7:34 AM
cabinet's Avatar
I talked to the dealer but surely they gave me no insight, but rather wanted me to bring it in for an expensive diagnosis.
Tootallmech
Equinox
August 7th, 2023 11:49 AM
uvamack
July 8th, 2011 12:14 PM
2007sl
Silverado & Fullsize Pick-ups
September 8th, 2010 2:14 PM
linkovich
August 21st, 2010 7:12 PM
Mastiff
July 12th, 2010 8:39 PM
Quick Reply: Steering lock-up & starting problems
