04 Express 2500 Rear Disc Brakes not working
Not my daily driver. Rear calipers fully free and sliding on pins nicely.
Parking brake works. 104000 miles. Rear wheel drive.
I rotated my tires yesterday, and noticed that both rear brakes do not seem to be energizing...just a small wear trace on rotors. Removed calipers from carriers...pistons not seized. Pushed brake pedal, small amount of piston movement noted, but didn't seem like enough. Re-installed calipers and cracked loose bleeder screws...no air, just fluid. The rear brakes don't seem to be applying/energizing. ABS lite present during bulbcheck only. No MIL's. Any experienced input would be appreciated.
There is a valve that with equal pressure on both sides stays in the middle. This allows fluid pressure to both sides of the braking system. Front to back I think. If you loose pressure and the valve slides over to block off the plow pressure side, then it might be stuck there. That would sewer your brakes on that part of the system. Check for a leak..
It is supposed to self centre once equal pressure is supplied once the leak is fixed. However I am not posetive on that.
You could give a brake shop or the dealership service folks and ask.
Once that piston slides over it is supposed to activate the brake warning light. Is that light on?
Scoobysam
Mar 29, 2015 9:30 AM
JRich_taco
Aug 31, 2013 12:16 AM
