1991 g20 transmission overdrive problem
Hi,
Last winter we rebuild our transmission on our 1991 g20 (Beauville) van since then i am missing the over drive. When i am driving up 100km/h and move from overdrive to regular drive no change in the RPM.
Fresh filter when rebuild the tranny and fluid level is up . It been working before i used a different tranny in the meantime of the rebuild.
Running out of idea why.
I did read that maybe a faulty temper sensor may cause problem is that true.
Thanks for ideas where to look .
TV cable should be set with foot pedal. If shop set it by opening throttle with hand,then it may have been overset. Remove doghouse, mash tv adjustment button. Floor the pedal,release button. Easy peasy
Dave de VA
March 18th, 2018 3:04 AM
shadetreestewart
July 14th, 2015 8:06 PM
