1995 G20 lower control arms
Old Oct 4, 2017 | 12:37 PM
95G20's Avatar
Newly Registered
Default 1995 G20 lower control arms
Where can I find lower control arms for my 1995 G20 van? They are no longer produced.
Can I use a G10 arm? Or an arm from a pick-up?
Old Oct 4, 2017 | 5:40 PM
Twscarp's Avatar
Try Car-Part.com Used Auto Parts Market.
Car-Part.com--Used Auto Parts Market
Old Oct 7, 2017 | 2:43 AM
Paul Fuller's Avatar
1973-1980 C series pickup control arms will work.
Old Oct 7, 2017 | 7:19 AM
Twscarp's Avatar
Can I respectfully ask how you know their compatibility, and where can they be found?
Old Oct 8, 2017 | 3:52 PM
Chevy built the front end with C series front end parts, check the part numbers for ball joints, bushings, upper control arm assemblies all are the same for corresponding parts between C and G series. A simple research on rockauto.com and you can see the numbers match. The cross member, idler arm, pitman arm, and tie rod assemblies are different.
I have a link somewhere are cross over front parts from a van forum somewhere if I find it I will post. Here is a ink to Summit for lower control arms for C20 pickup. https://goo.gl/HXEzER here is listing for C10: https://goo.gl/cGXyFK
You can research if the C20 fits the G20. I do know that the C10 fits the G10. I just ordered a bunch of front end parts for my G10, all fit.
Old Oct 8, 2017 | 3:56 PM
Also ebay for a pair.
https://goo.gl/SFCuV6
Old Oct 9, 2017 | 10:03 AM
Twscarp's Avatar
Assured compatibility is very elusive, why the manufactures wouldn't include the full range of models and years makes me skeptical, but thanks for the info.
Old Oct 9, 2017 | 11:22 AM
StanVan's Avatar
15 Year Member
Rock Auto sometimes has a button for inter-species compatibility. But as a former parts guy(motorcycle), a part number is not exclusive to any model. Honda's parts numbering system tells you the model that the part was originally designed for, but it can show up anywhere, even a car part on a bike(or vice versa).
Old Nov 16, 2017 | 12:41 PM
cablesplicer's Avatar
I got my 87 g30 upper / lower control arms from rockauto , much cheeper then advance / auto zone and in the ''info'' button it showed all models it fit. Mine is a bucket van and is 9500 lb.'s empty [the suspension and rear axle have been upgraded ]and i have had no troubles with them . I also added new springs from them at the same time. I hope this helps and good luck.
Old Mar 18, 2018 | 2:14 AM
ThroatwarblerMangrove's Avatar
My parts book indicates the 1992 G-10 and G-20 lower control arms are the same. 1995 SHOULD be the same as 1992.
If it helps: RH GM 15594134
LH GM 15594135
