1996 5.0 will not restart at running temp
Old Jan 14, 2017 | 8:13 AM
MANOFTHETIRE's Avatar
Default 1996 5.0 will not restart at running temp
Hi all,
I'm having a problem with my 1996 5.0 van, it Will start fine when cold but when it gets to running temperature, and you shut it off To go into store or something and try to restart it will not start until you give it gas, than it will start. No codes come up, no idea what's wrong, any help would be appreciated
thanks in advance
Old Jan 14, 2017 | 8:34 AM
SnlpeR's Avatar
does it start up normally after you leave the key to the 2nd position for like 10 secs or until the security light goes out?
Old Jan 14, 2017 | 12:24 PM
No it does not but you let it sit for 15 to 20 minutes it will start right up with no problem
Old Jan 14, 2017 | 2:34 PM
canucklehead's Avatar
Sounds like a fuel issue....pressure regulator or something. Try cleaning the MAF sensor. Check your air filter, fuel filter etc.
Giving a little throttle may be allowing the extra air it needs into the throttle body......if its flooding.
When you start it hot and shut it off can you smell rich exhaust?
Old Jan 14, 2017 | 6:35 PM
No we haven't noticed a rich smell but will see if we smell anything the next time we crank it thanks
Old Jan 14, 2017 | 7:29 PM
SnlpeR's Avatar
does it start right up if you quickly turn the key after putting it in?
like without letting the fuel pump prime
Old Jan 15, 2017 | 6:45 AM
No we always let the pump prime, it will not restart until you press the gas. After you let it sit 15 to 20 mins it will start without pushing gas, we have been working on this in the yard , don't want to drive around town and get stuck with it not restarting
Old Jan 15, 2017 | 9:20 AM
multipoint injection or throttlebody?
Old Jan 15, 2017 | 2:07 PM
Its got a Throttlebody
Old Jan 16, 2017 | 12:55 AM
i was wondering if the injectors are leaking down into the throttle body. shut it off and watch the injectors for 5 minutes.
