2000 chevy Express throwing code
Old Feb 20, 2014 | 2:05 PM
cat320's Avatar
Default 2000 chevy Express throwing code
I have a 2000 chevy express 3500 with the 5.7 liter engine has roughly 80K or so on it . we brought it to the body shop truck was running great they had it for 1 week got it back was running so rough. it has had new plugs and wires not long ago. we scanned it and found a trouble code PO137 and under that it said 02 circuit low voltage then Bank 1 sensor 2.
Has any one ever had this code and know where or what it is?
Old Feb 20, 2014 | 3:37 PM
canucklehead's Avatar
O2 sensor needs replacing. I would do all 4. Not just one. The 2 upstream ones feed info to the computer for fuel mixture and timing. If they are out, then rough running could result.
Old Mar 19, 2014 | 4:05 PM
cat320's Avatar
we started looking at what the problem might be we did cap and rotor after market and plugs and wires less than a year ago. we checked them all over again. we bought a GM cap and rotor because we heard that it may be the whole problem checked the plugs and wire. looking for a cause on the driver side plug closest to the bumper not firing right. is there something else that we could be missing.
Old Mar 19, 2014 | 5:48 PM
Jeez. Did you not read my last post?...lol
You said...
............02 circuit low voltage then Bank 1 sensor 2....
02 means Oxygen Sensor. Its part of the emission control system on the exhaust pipes after the manifolds. 2 before the catylitic converters and 2 after
Fix that first. Then see.
pippo047
May 6, 2013 10:18 PM
ethanbrogden
Jun 13, 2011 1:01 PM
mapsurfer
Mar 1, 2011 7:04 AM
PastorK
Feb 17, 2010 9:31 PM
joatman
Aug 12, 2009 8:45 AM
