2000 express 3500 A/C issue
The compressor will not turn on. I've traced the issue to the compressor relay/VCM trigger signal. The hi and low switches seem to be working correctly and giving the vcm the proper signal but the control line from the vcm to the relay (i believe is Drk grn/white wire) doesn't seem to be supplying the signal to the relay coil.
can someone verify which connector and which wire from the vcm is the trigger wire?
schluk5
September 16th, 2020 5:32 PM
Bagged87chevy
1988 - 1998 (GMT400)
June 21st, 2019 5:51 PM
