2005 4.8 Vortec - What oil is best + Trans fluid ?
Old Dec 22, 2023 | 1:25 PM
Trackvw's Avatar
Default 2005 4.8 Vortec - What oil is best + Trans fluid ?
Hi , I wanted to change my oil and maybe my Trans fluid ,
Whats the best oil to use , I am not sure if there is better oil than that recommended when it was new ?
Also trans fluid , would you change it all , or just some as I have heard people have had problems flushing out all the old stuff !
Thanks for your advise
Old Dec 22, 2023 | 3:24 PM
Don't overthink it. Use whatever oil meet the specifications given in your owner's manual. Brand doesn't matter they're all the same.
Depends. How many miles on your transmission?
How is the transmission shifting? Are the gears getting kind of mushy?
Take a sample of the fluid. What does it look like?
Old Dec 23, 2023 | 9:46 AM
Triaged's Avatar
I'm of the opinion that all synthetic oils are so good these days it isn't worth paying more for a great oil. I use Kirkland 5w30. I do think a good filter is worth having. I've looked at the tests and teardowns and concluded that Fram ultra synthetic XG10575 is the current best bang for the buck. It crosses over to PF63.
Trans, I'd drain, put in an extra magnet in the pan, a drain plug and fill with GM stuff.
Old Dec 23, 2023 | 10:15 AM
Rednucleus's Avatar
Probably being faithful with regular changes is much more important than the brand.
Old Dec 23, 2023 | 11:31 AM
Trackvw's Avatar
thanks , I do not have an owners manual but 5-30 seems good , I am not pulling heavy trailers or going up mountains !
What trans fluid , and are any additives worth adding ,
The truck has 155 K on it and decent upkeep
Old Dec 23, 2023 | 1:25 PM
Triaged's Avatar
thanks , I do not have an owners manual but 5-30 seems good...
https://www.chevrolet.com/support/ve...&model=Express
Old Dec 23, 2023 | 4:30 PM
you can get them online now
https://experience.gm.com/support/ve...manuals-guides
doesn't matter. The fluid still should be changed every 50-60k. Maybe even more frequently as it gets up there in miles.
Dexron IV. Do not use additives if the trans works fine.
Old Dec 25, 2023 | 9:03 AM
jjrbus's Avatar
I am impressed often which oil to use brings on a flurry of recommendations sometimes leading to arguments. Modern oils are miraculous compared to way back so I use what ever is on sale. Which reminds me it is time for my oil change.
This guy makes some interesting comparison videos.
Lopaka2014
2014 - 2018 (GMT-K2)
Sep 4, 2022 1:55 AM
honda fiddy
Aug 31, 2021 8:33 PM
sprayking
Nov 23, 2011 9:06 PM
hamcginn
Colorado
Feb 5, 2008 4:57 PM
hamcginn
Jan 26, 2008 11:01 AM
