2008 Express 2500 short
Old Oct 2, 2019 | 2:12 PM
Mayson Wade Johnson's Avatar
Default 2008 Express 2500 short
I have a 2008 chevy express 2500. at random times all of the gauges in the van drop except the battery. Then almost every light comes on, ABS, brake light, check engine etc... When this happens the van also shifts very hard and rough however continues cruising as high speeds just fine. Entire fuse box was replaced and issue is still there. Issue comes in and out. Sometimes with bad weather it runs fine. Any ideas would be greatly appreciated.
Old Oct 2, 2019 | 2:50 PM
Sounds like a broken wire in the harness or faulty control unit. Intermittent problems are tricky. Obd scan tools might give you clues.
Old Oct 2, 2019 | 3:20 PM
Twscarp's Avatar
Hi, I had similar issue with my 2008 1500 4.3l, check out the post: https://chevroletforum.com/forum/exp...-repair-78517/
Old Oct 8, 2019 | 7:22 PM
tsoleno's Avatar
Check the connector from the instrument panel @ the body harness
shepherdsflock
Mar 17, 2015 6:21 PM
tmontplumbing
Jun 3, 2014 2:03 PM
eddychevy
Dec 7, 2012 1:39 PM
2008express
Sep 28, 2011 5:00 PM
oldblue92
Apr 28, 2011 12:13 PM
