2014 GMC Savana 2500 4.8L - Brake Pull
Old Aug 31, 2023 | 9:42 AM
ChevGirl1981's Avatar
Question 2014 GMC Savana 2500 4.8L - Brake Pull
Help! We are at a loss and are hoping someone has maybe encountered this issue before. This van has a wicked / scary pull to the right when applying brakes at a high rate of speed, but only after brakes have heated up. We have already done the following, and sometimes twice to be safe, and this still eludes us. We have changed front and rear pads / rotors /calipers, we have changed all four brake flex hoses, we have done multiple alignments, multiple rotations and a new set of tires, an ABS pump, a right front wheel bearing, replaced pitman arm, idler arm and bracket, inner and outer tie rods. Replace all four shocks and ground strap. Rear leaf springs are not broken or saggy, front control arm bushings all intact with no play, frame is not bent.....what are we missing? Again wicked pull to the right when hard braking from highway speeds, but only after brakes heat up....
Old Aug 31, 2023 | 2:20 PM
Did you check for play in the bearings on the other three wheels?
Old Aug 31, 2023 | 2:47 PM
The rear bearings are in the axle, they are able to check only for vertical play which there is non of, and they did check the left front bearing and no play was found...
Old Aug 31, 2023 | 2:55 PM
Maybe if you go for a drive to get things nice and hot, and then quickly jack up the vehicle and test the brakes, you will at least be able to tell which wheel is dragging.
Old Aug 31, 2023 | 3:01 PM
That has been done as well, no brake drag occurred All four calipers have been changed..twice, all hoses have been changed with OE hoses, and parking brake was backed all the way off to make sure that wasn't the culprit, even went so far as to pull abs fuse so that did not interfere and pull is still there, I also forgot to mention, that when it does jerk to the right it feels like it is coming from the rear end.
Old Aug 31, 2023 | 3:08 PM
I wonder if the rear brake lines are failing, and it's only detectable when the suspension is compressed.
Old Aug 31, 2023 | 3:25 PM
Are you talking about the hard lines?
Old Aug 31, 2023 | 3:33 PM
yes. The rear ones are more exposed and tend to deteriorate faster.
Old Aug 31, 2023 | 3:35 PM
Is there a way to notice if they are failing if they show no signs of leaks starting?
Old Aug 31, 2023 | 3:46 PM
Not sure. But if there's a kink or internal blockage then it might not show from the outside.
