2024 steering wheel audio controls
24 express has been built on on its way to me. Bare bones audio choice, and obviously without steering wheel audio controls. 1} upgrade audio 2} new steering wheel. How difficult will this transition be? Thanks for reading and your advice!
It's remove and replace if you get the whole wheel. It's remove horn/airbag, remove wire harness, cut hole, install switch, install wire harness if you want to just add the switch to your wheel. Pictures below of parts and where they go. I'll be doing this when I get a bit more time.
Steering wheel audio controls wire harness
Steering wheel audio control switch
Cut hole here
Poke here both sides to remove airbag/horn. Follow safety instructions.
Cut hole here
RoadTrip (April 14th, 2024)
heavy chevy09
December 11th, 2011 4:49 PM
