84 G30 washer jug and pump
Old Feb 24, 2020 | 12:58 AM
ChrisKrowchuk's Avatar
Default 84 G30 washer jug and pump
I picked up an 84 Winnebago built on a G30. Live in the desert so not much need to turn in the wipers since I picked it up! Went to fill the washer fluid... no jug, no pump. The mount bracket is there along with a hose and 2 blade power connector. Picture attached.
having no luck finding a jug that fits an 84 g30 specifically. Anyone know the year range that this part was common on? Or where I might dig one up?
Missing washer jug and pump
Old Feb 24, 2020 | 9:37 PM
I would recommend the junkyard . It should be the same for G10/G20/G30 within few years.
If not, there are aftermarket universal kits.
https://www.napaonline.com/en/p/BK_6651594
Old Feb 29, 2020 | 12:31 AM
Beau Oszman's Avatar
Junk yard. The washer res mount looks the same as my '93. Likely be able to use one from anything up to '95, maybe even newer. The pump should be available from the local parts store. I would suspect if the bottle is the same, the pump likely is too.
Railroadertwo
Oct 3, 2014 10:16 PM
ladyhawkjj
May 8, 2014 10:47 PM
huey113
Jan 31, 2010 12:16 AM
95 Suburban
Jan 13, 2009 10:19 PM
mrsmoos
Jul 8, 2008 4:18 PM
