91 Vandura G1500 fuel issue
Old May 18, 2024 | 8:32 PM
  #11
Triaged's Avatar
I guess I can't see where it's leaking. Can you describe it better? I see some Teflon tape on the fuel lines. That doesn't belong there. Those are o-ring fittings. Maybe it was overtightened to try and seal it up causing the leak? Is it the adapter that is causing the leak? Or is it the housing of the throttle body itself?
Old May 18, 2024 | 8:41 PM
  #12
gfunkadunk's Avatar
Circled it. You can see the drips of gas. It's cracked on the housing, just behind where the 3/4" fitting goes on. Must've been like that when I got it.
Old May 18, 2024 | 8:47 PM
  #13
Triaged's Avatar
These are the adapters. One of those cracked or the TB itself?
https://www.flickr.com/photos/fission_chips/7618455664/
Old May 18, 2024 | 8:50 PM
  #14
gfunkadunk's Avatar
Read my last post I answered that
Old May 18, 2024 | 9:33 PM
  #15
Triaged's Avatar
Well good luck with the JBWeld. Even if works temporarily it likely won't work long term because of the ethanol in fuel. Personally I'd take it off, take it all apart, clean it very well, and try some green loctite in the crack because it could weep down into the crack. I'd likely use loctite on the adapter too... then JBWeld over the top of it.
Old May 18, 2024 | 9:38 PM
  #16
Triaged's Avatar
https://www.ebay.com/itm/272495069536
Old May 18, 2024 | 9:42 PM
  #17
Triaged's Avatar
https://www.ebay.com/itm/156173077858
If I remember correctly, the 4.3 and SBC all had the same TBI with different injectors. The TPS and IAC I think changed a time or 2.
Old May 18, 2024 | 9:47 PM
  #18
Triaged's Avatar
LKQ doesn't deal with stuff this old. No idea what you have for wrecking yards around you but you can try car-part.com
It is only as good as the actual yard you are dealing with but you should be able to find a new TBI.
Old May 19, 2024 | 12:20 PM
  #19
gfunkadunk's Avatar
I'm a couple hours drive away from the nearest wrecking yard. Just trying to get a bandaid on this thing for now. I have found a 4.3 vortec for sale I might pick up.
This engine is in bad shape and hardly worth putting anything into. I did the head gaskets when I got the van, lot of damage in one cylinder, bad wear in the others, broken boss on one of the starter mounts, 285 000km, holes rusted into the rocker covers, I could go on.... But the brakes, frame, suspension, transmission, exhaust all seem good, some rust holes on the body but I'm good at bodywork.
So I should get it running and go get that other engine
Old May 19, 2024 | 1:52 PM
  #20
gfunkadunk's Avatar
Dodgy fix holding the fuel line in just the right position with a bungee cord and a strap and it works lol. Better keep a fire extinguisher at hand
I'm embarrassed to say I also had a blown fuse on the fuel pump circuit. I didn't check this right away because it had the same symptoms as it did a couple months ago and that was not the issue. I should know better and always check the simplest things first!
87chevyman
Feb 13, 2024 2:09 PM
steve_bl
Nov 7, 2022 10:46 PM
lunyty
Dec 3, 2010 9:07 PM
macruadhi
Aug 9, 2010 9:23 PM
Enstar
13
Jun 22, 2007 10:36 PM
