Add Posi - just rebuilt rear end
Old Apr 28, 2018 | 10:14 PM
boisevan's Avatar
Default Add Posi - just rebuilt rear end
Hi. I love my 1988 GMC camper van.
I just had a local shop put new bearings in the rear end. It was howling.
I want to add positraction now. Should have thought of that when they had the rear end opened up.
I’ve read that I can buy a Detroit Locker and that does the trick.
But will that Locker still use the nice new bearings I just paid to install? Or do the new bearings get scrapped?
Old Apr 29, 2018 | 12:41 AM
you can probably keep em.
Old Apr 29, 2018 | 9:58 AM
StanVan's Avatar
15 Year Member
I don't know about an '88, but GM used multiple differentials in any given year. For example, my '16 could be either a 9.5" or a 10.5", and both are 14 bolt. The best way to know is to have a dealer run your VIN.
Old Apr 29, 2018 | 3:41 PM
canucklehead's Avatar
Yes, you should have done both jobs at once. Doing the locker install comes with new bearings.....lol
The bearings get pressed onto the carrier I believe, and you will be getting a new carrier with the detroit tru track. Your old ring and pinion can still be used
Old Apr 29, 2018 | 4:01 PM
Bearings are not pressed into the carrier. See Step #9
https://www.chevydiy.com/how-to-disa...-step-by-step/
Old Apr 29, 2018 | 4:57 PM
oilcanhenry's Avatar
The DT locker isn't the same as Posi-traction, I hope you know. Be careful to use the correct lubricant and additives.
Old Apr 30, 2018 | 7:36 AM
The outer race is held by the clamps, the inner race and bearing is pressed onto the carrier. Your step 9 only shows the carrier removal. If it was not pressed on the inner race would spin on the machined surface.
Old Apr 30, 2018 | 3:22 PM
No, no, I was right. They aren't pressed into it; they're pressed ONTO it. Just like you said haha. Thanks for clarifying.
Sorry, OP. Maybe you can keep them as spares.
Old Apr 30, 2018 | 7:45 PM
I have the g80 and the teeth were broken. I paid an axle shop 600 bucks for a new carrier and I believe ( cannot remember) he used new bearings. He also quoted me 1200 for a detroit tru track, since the g80 is not that tough. That is our funny coloured over taxed canadian dollars.....
