Adding aftermarket accessories to group 78 battery
Old Jan 16, 2023 | 2:29 PM
jamesm113's Avatar
Default Adding aftermarket accessories to group 78 battery
I have several aftermarket accessories that need a direct line to the battery (subwoofer, etc).
Up until this point, I have had a Group 34/78 battery that has both sets of battery terminals, so I've just attached them to the top posts.
However, that battery died and now the replacement battery is a Group 78 that does not have the top posts. Curious how others have connected their devices.
Thanks!
EDIT: 2013 Chevy Express 2500
Old Jan 16, 2023 | 3:02 PM
What accessories?
Old Jan 16, 2023 | 3:05 PM
jamesm113's Avatar
Currently, I have a subwoofer and a light bar attached with ring terminals on a ring terminal connector.
In the future, might add an ARB compressor as well.
Old Jan 16, 2023 | 4:02 PM
og52's Avatar
I used the POS battery terminal of the underhood fuse box.
Added an 8 gauge wire to an auxiliary fuse box for my accessories, auxiliary lighting and trailer brake control.
Old Jan 16, 2023 | 8:27 PM
Yeah as long as you're not adding more than a few hundred watts of load, you can use the auxiliary positive stud in your underhood fuse box. Make sure you connect after the factory megafuse if you have one (you did not give us any details about what vehicle you're driving) or you'll fry your wiring.
Old Jan 16, 2023 | 8:28 PM
jamesm113's Avatar
Old Jan 16, 2023 | 8:29 PM
jamesm113's Avatar
Also - does there happen to be a lead I can tap into that is switched on and off with the ignition?
Old Jan 23, 2023 | 7:46 PM
jamesm113's Avatar
One of these stud posts should do the job nicely:
Amazon Amazon
EDIT: Or this from Autozone: https://www.autozone.com/batteries-s...der/296092_0_0
Old Jan 23, 2023 | 8:40 PM
Compressors can draw a lot of inrush current. You should probably give it a dedicated circuit.
You'll need a break-out fuse panel connected to battery, and run the circuit through a relay energized by a manual switch.
I would be extremely careful about hacking into existing wiring if you don't want problems down the road. GM electricals are not exactly confidence inspiring to begin with.
See the electrical manuals on gmupfitter.com
Richard Yao
Avalanche
Jan 10, 2017 5:25 AM
gray gables
Sep 26, 2012 10:00 PM
TAHOE2005
Jun 1, 2010 9:19 PM
Tieffun
May 22, 2010 6:12 AM
ousig2408
Feb 18, 2010 12:40 PM
