Anybody have air shocks?
I just installed air shocks on my 95 conversion van. With all the conversion stuff, and being 25 years old, it needs a little help. It's kind of always towing. I remember in the 80's i put air shocks on a Camaro and it would jack it WAY up. ha ha.
These shocks have a 200 psi max. I can only pump them up to about 150 psi and it only raises it .5 inch.
Is there so much weight that it's not going to really lift it much? Like the best I should expect would be to restore or maintain factory height?
I don't even have a way to pump past 150 psi...
what product did you install? post a link.
springs are designed to support weight. shocks are designed to stop jounce and rebound oscillation, not correct ride height. I know gm used factory air shocks for leveling but an air spring is a better alternative.
Good luck
Old school mechanic
guvner
August 22nd, 2013 12:29 AM
