Anybody have air shocks?
Old Jan 30, 2021 | 6:45 PM
johnt365's Avatar
Default Anybody have air shocks?
I just installed air shocks on my 95 conversion van. With all the conversion stuff, and being 25 years old, it needs a little help. It's kind of always towing. I remember in the 80's i put air shocks on a Camaro and it would jack it WAY up. ha ha.
These shocks have a 200 psi max. I can only pump them up to about 150 psi and it only raises it .5 inch.
Is there so much weight that it's not going to really lift it much? Like the best I should expect would be to restore or maintain factory height?
I don't even have a way to pump past 150 psi...
Old Jan 31, 2021 | 11:10 PM
what product did you install? post a link.
springs are designed to support weight. shocks are designed to stop jounce and rebound oscillation, not correct ride height. I know gm used factory air shocks for leveling but an air spring is a better alternative.
Old Apr 1, 2021 | 6:37 AM
Paul Garrison's Avatar
Air shocks weren't designed to change height of vehicle. They were designed to adjust ride according load. If you're looking to change height add adjustable shackles. But keep in mind old springs sag. You may need new springs. If you changed engine from six cylinder to eight cylinder. You will need V8 springs. And maybe complete V8 suspension. I've used air shock's and found best ride between 60 and 80 PSI.
Good luck
Old school mechanic
flh69
Oct 14, 2013 12:27 PM
justinhalverson56
Mar 22, 2010 9:26 PM
too_many_hobbies
Oct 25, 2007 9:07 PM
bigsid
Sep 17, 2006 2:07 AM
