Auto to manual swap
Old Feb 28, 2024 | 2:03 PM
gfunkadunk's Avatar
Default Auto to manual swap
So it's time to replace my 4.3 in my 91 Vandura, I am considering a 4.3 vortec and a manual transmission. What difficulties should I expect to run into and what parts and transmission should I be looking for?
thanks
Old Feb 28, 2024 | 5:43 PM
I’m pretty sure that the crankshafts are different
Old Feb 28, 2024 | 7:39 PM
gfunkadunk's Avatar
​I'm talking about fitting a new engine and trans. Mounting points might be different, driveshaft length, I don't know. But a manual van with a floor mount shifter would be pretty sweet
Old Feb 28, 2024 | 8:49 PM
I understand what you're talking about. I said I'm pretty sure the engines are different depending if you're hooking it up to a manual or automatic, so that's something to keep in mind, since you asked.
The vans haven't had a manual transmission since the 80's (before yours), so you're looking for some old equipment, and likely some custom mounting.
Old Feb 28, 2024 | 9:02 PM
gfunkadunk's Avatar
Any problem getting a manual engine and trans from a truck? Will a truck engine bolt right into a van?
Old Feb 28, 2024 | 9:11 PM
no clue. You are venturing in custom territory which means doing your own measuring and fabbing.
Old Feb 29, 2024 | 8:18 AM
Derrick71's Avatar
You're going to have to come up with some sort of shifter linkage to have the shifter on the floor. In a truck the engine is up front with the tranny between the front seats. In a van the shifter would come up too far back to be practical.
You'd have to rig up something like a front drive manual has where the stick goes into a shifting mechanism bolted to the floor and transerres the movements to the tranny through cables or rods.
Old Feb 29, 2024 | 9:58 AM
gfunkadunk's Avatar
Yeah that would be necessary but shouldn't be too difficult. Lot of options available.
Now if I'm going to all that effort, maybe I should just center mount a twin turbo LS and make a GMC super van!
Old Mar 1, 2024 | 12:39 PM
Derrick71's Avatar
Cdog
May 16, 2023 3:21 PM
robert912004
Jan 4, 2015 12:27 AM
gmanuel11
Chevelle & El Camino
Nov 19, 2012 9:03 AM
mjd1686@hotmail.com
Apr 5, 2011 11:51 PM
FREEDOM
Jan 19, 2009 12:59 AM
