Battery charging system battery light on
Old Feb 10, 2024 | 1:07 PM
Idkchevy1234's Avatar
Default Battery charging system battery light on
2009chevy express 2500 I got a battery charging system wit battery light on on my van no check engine is there a fuse or relay for the altenator I also change my battery light still on heavy rain for 5 days idk if this may be the cause
Old Feb 10, 2024 | 1:52 PM
Is the alternator charging?
Old Feb 10, 2024 | 2:16 PM
idk visual inspection looks normal
Old Feb 10, 2024 | 2:31 PM
have your battery + alternator load tested. They'll do it for free at the battery dealer, or autozone, etc.
Old Feb 10, 2024 | 2:33 PM
I change my battery light still on is there any relays for the alternator
Old Feb 10, 2024 | 2:38 PM
No, the alternator is on all the time, but there's a fusible link.
you cannot visually inspect an alternator. It has to be measured under load.
Old Feb 10, 2024 | 2:39 PM
where can I find the fusible link
Old Feb 10, 2024 | 2:45 PM
On the cable from the alternator to your battery.
But if that was bad then your van wouldn't run at all.
Old Feb 10, 2024 | 2:56 PM
For some reason my stereo went out on Monday no sound then Friday I got that message on dashboard
Old Feb 10, 2024 | 2:59 PM
