brake petal issue
brake petal issue
I have a 2007 express van. Recently heard a small motor running then as if it popped. I now have a brake petal issue. It feels as if the abs is being engaged but only on slow slops. Any help???
My 03 van did the same thing. As you come to a slow stop the ABS would engage. With 30K miles the dealer hooked up ABS logging software and found a right wheel bearing sender was showing the wheel locking so they replace the wheel bearing/abs assembly under warranty. Then at 65K it was doing it again so I changed the left side and it hasn't happen again since. I tried pulling ABS codes and their were none. Try hitting them hard at about 20MPH on dry pavement and if it pulls to one side then I would start with the other side. Hope this helps.
Slobby Baymon
November 12th, 2013 11:52 PM
cmcbride
Avalanche
August 8th, 2012 3:12 PM
