brake petal issue
Old Dec 29, 2011 | 3:03 PM
martygreen's Avatar
Default brake petal issue
I have a 2007 express van. Recently heard a small motor running then as if it popped. I now have a brake petal issue. It feels as if the abs is being engaged but only on slow slops. Any help???
Old Jan 1, 2012 | 5:23 PM
StanVan's Avatar
15 Year Member
That motor sound is probably your ABS engaging somehow.
Old Jan 4, 2012 | 8:40 AM
zman70's Avatar
My 03 van did the same thing. As you come to a slow stop the ABS would engage. With 30K miles the dealer hooked up ABS logging software and found a right wheel bearing sender was showing the wheel locking so they replace the wheel bearing/abs assembly under warranty. Then at 65K it was doing it again so I changed the left side and it hasn't happen again since. I tried pulling ABS codes and their were none. Try hitting them hard at about 20MPH on dry pavement and if it pulls to one side then I would start with the other side. Hope this helps.
Slobby Baymon
Nov 12, 2013 11:52 PM
cmcbride
Avalanche
Aug 8, 2012 3:12 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
tom5170
Mar 19, 2010 11:57 PM
