A/C not working, any ideas?
Old Jun 23, 2010 | 6:19 AM
saabman's Avatar
Question A/C not working, any ideas?
Hi
I am having trouble with my Air Conditioning on my 1998 Chevy Express Passenger 2500 Van.
so far I have checked the fuse near the driver's foot well and also notice that the compressor does not seem to engage when I switch the blower to AC
Do any of you have any suggestions of extra troubleshooting before I get taking things apart?
Many Thanx
Old Jun 23, 2010 | 8:33 PM
MDTAHOE's Avatar
Professional Mechanic
System is most likely empty
Old Jun 24, 2010 | 2:23 AM
saabman's Avatar
Thanx for your answer, but shouldn't I hear the compressor click on when I switch to AC? Even if the system is empty?
Old Jun 24, 2010 | 6:36 AM
MDTAHOE's Avatar
It will not come on if the pressure is too low.
Old Jul 17, 2010 | 9:34 AM
EnyChevyUK's Avatar
My 98 Express a/c compressor clicks in when switched on but I'm not getting ice cold air (just regular cold like when a/c is not selected).
Am I correct in thinking I need a top up as I probably have enough refrigerant pressure to activate the compressor but not enough to generate the cold ?
The a/c metal hoses are not cold and do not generate any moisture/condensation on them.
Thanks.
(when I bought the van , the a/c did not work at all. I had the refrigerant replaced and everything started to work , compressor etc).
Saabman, just have the refrigerant replaced. Hopefully none of the seals have perished due to lack of use !
Old Jul 19, 2010 | 2:07 AM
saabman's Avatar
Hi
Well I had the system refilled and discovered the caps where missing on the upper and lower connections... this (so I was told by the expert) might have been the reason for my loss of gas... He used a tracer to check for leaks and all seems to be OK now...
Lucky as I have just driven 1500 miles round trip in one of the hottest summers for a while here in Europe...
Thanx for all you replies
chevywilly
Nov 26, 2014 6:05 PM
surfridefish
Feb 14, 2012 5:20 PM
surfridefish
Feb 11, 2012 9:18 PM
mccalljb
Mar 3, 2010 9:26 PM
shayneneal
Aug 27, 2009 5:52 PM
