Chevy G30 Sportvan Having Issues With The Fuel Pump?
Old Oct 23, 2023 | 4:06 PM
HerzeleidMeister's Avatar
Default Chevy G30 Sportvan Having Issues With The Fuel Pump?
My thought is that my van needs a new fuel pump. I've replaced the fuel filter & the alternator already, so neither should be causing the issues I'm having.
Issues I'm Having:
  • Trouble starting. It does not start right up like it used to.
  • It stalls if I take my foot off the gas
  • It will sometimes stall as I'm driving
  • I have to keep on pumping the gas for it to move
  • Its backfiring a lot
  • When I do finally get going it will decelerate on its own and if I give it gas it kinda bogs down and is hard to go any faster
  • It will shudder sometimes
Everything I've looked up indicates that this maybe a fuel pump issue, but I want to make sure before we drop the tank and try fixing it. I do plan on buying the whole assembly, not just the pump. Any info would be appreciated. TIA!
Old Oct 23, 2023 | 7:01 PM
if you want to make sure, then measure the fuel pressure with a gauge.
Old Oct 25, 2023 | 3:48 PM
Ok I'll ask my mechanic about doing that. Are there any other thoughts on this?
Old Oct 25, 2023 | 4:03 PM
Rednucleus's Avatar
I guess if I had a mechanic doing the work, I would expect them to perform appropriate diagnostics, not throw parts.
What year, what motor ...
Old Oct 25, 2023 | 4:36 PM
Originally Posted by rednucleus
i guess if i had a mechanic doing the work, i would expect them to perform appropriate diagnostics, not throw parts.
1995 5.7 v8
dadlewis
Astro
Aug 31, 2017 7:21 AM
hubcaper
Dec 20, 2011 9:00 PM
chevy_mark
Mar 24, 2011 9:11 AM
gigawiz
Dec 5, 2009 11:51 PM
LHHEMS
Dec 28, 2007 7:18 AM
