Crank no start. good spark but, no power to fuel pump.
Old Mar 18, 2025 | 4:57 AM
dsk's Avatar
dsk
Default Crank no start. good spark but, no power to fuel pump.
Hello
i have a 2021 chevy express van 4500 cutaway chassis with 6.6L L8T gasoline engine.
It crank but no start so I have changed to fuel pump. but same problem.
DTC P129F
1_ no power when check with test light the fuel pump fuse. with key off and also ignition on. Visualy checking the fuse it looked good. and also try to crank by changing the relay but nothing changed.
checked fuse : n. 24
checked relay : 38
2_ nothing happens(no running) even when i jumped a wire from the battery+ to the fuel pump fuse and crank.
3_ fuel pump control module fuse has power when test with test light.
checked fuse : n.36
local non chevy engineer told me that the issue might be the fuel pump control module.
is he correct? or I need to do more checking please.
dcramer
2007 - 2013 (GMT900)
11
Mar 13, 2023 5:31 PM
Ulluvit
1988 - 1998 (GMT400)
Nov 10, 2022 9:04 PM
Robertt
Apr 30, 2019 12:58 PM
mcessna1222
Jan 17, 2016 3:00 PM
lil754boy
Jan 31, 2008 6:11 AM
