Dome Light not Working on 2004 Chevy Express Mini Bus
Old Apr 29, 2024 | 10:56 AM
ShadeyJones's Avatar
Default Dome Light not Working on 2004 Chevy Express Mini Bus
Need Help.
Just got this bus and converting it to a RV/Skoolie.
EVERYTHING Else works, just cant get the Dome light to work.
I have changed the bulb, checked all fuses and relays in the engine area and under the seat and in the overhead compartment of the Bus.
Replaced the Headlight Switch panel, still no lights even after having the dimmer dial clicked to the right and checked the over ride button.
Someone mentioned elsewhere that it might be the switch in the door latch area so i cut the wires and find 4 wires pictured below. Not sure how to connect them to bypass the switch?
Any help will be appreciated
Old Apr 29, 2024 | 11:56 AM
Welcome from Florida. Did you check if there was a good ground to the dome light?
Old May 3, 2024 | 12:51 AM
Yes i did.
Im trying to figure out the 4 wires in the door jam are for and what should be present on them on my meter.
NovaMerc
Apr 21, 2022 8:09 AM
matthew74
Jan 26, 2019 9:48 AM
SOLOLUCKY
Dec 30, 2016 10:37 AM
NHsilveradoLT
11
Aug 11, 2014 3:51 PM
Sharpcop
Nov 8, 2010 1:56 AM
