2004 Suburban Dome and Map Lights not working.
Old Apr 18, 2022 | 3:42 PM
NovaMerc's Avatar
Default 2004 Suburban Dome and Map Lights not working.
Ok so I'm going a little crazy here. I recently bought an 04 suburban and it was missing the center dome light and the map lights don't work. So naturally i figured some has already tried fixing this before considering they pulled the light out and didn't replace it. Used my multimeter got no voltage at the center dome light harness. So I decided to get a new dome light and chase it down after that. I get the new light started checking fuses checked all the three tbc fuses. All good. I've checked every fuse in this suburban they are all good. I just can't get any voltage to the dome light. There rear dome lights works fine and so does the over ride switch.
Old Apr 18, 2022 | 4:01 PM
hanky's Avatar
If the center dome light has only one wire supplying power to it , the body of the light may have no ground.
Does it have more than one wire going to it?
Old Apr 18, 2022 | 5:02 PM
NovaMerc's Avatar
It's a two wire clip and there was no voltage.
Old Apr 18, 2022 | 5:04 PM
NovaMerc's Avatar
Ok sooo now its the other way around my buddy slammed the door now every light works except the rear one so I'm really lost now.
Old Apr 20, 2022 | 9:39 AM
NovaMerc's Avatar
And now its back to the way i originally described it
Old Apr 21, 2022 | 8:09 AM
repairman54's Avatar
You need a shop manual with the wiring diagrams that show all the color coding of the harness to trace it down properly along with a good meter.
tmise
Jun 10, 2021 2:59 PM
RyanRay1984
Jan 14, 2021 12:27 AM
Disasterman
Apr 23, 2019 3:18 PM
Chris1998
Sep 22, 2015 1:06 PM
210glenn
Astro
Oct 17, 2010 9:07 PM
