Efi retrofit
Old Sep 18, 2019 | 1:54 PM
Jacob Wiseman's Avatar
Default Efi retrofit
Hi I have an 85 g20 with a carbureted 305. Is it possible to take the efi system off a later year model 305 and make it work in my 305?
Thanks, Jacob Wiseman
Old Sep 18, 2019 | 11:01 PM
SteveROntario's Avatar
There are lots of aftermarket kits available.
Old Sep 19, 2019 | 5:28 AM
Yes, but I didn't ask that, I know there are very expensive aftermarket kits.
Old Sep 19, 2019 | 5:10 PM
oilcanhenry's Avatar
Might be possible with a late 80's-early 90's pre OBD II TBI injection unit, but you would have to install a fuel pump capable of maintaining 55-62 PSI for the injectors to operate properly. and an intake manifold too. You'd need an ECM for the system as well. Likely need a new distributor and coil too. If you can get good used parts it might be worth it. Also an air filter that would fit the TBI unit. What kind of carb do you have currently?
Edit: My mistake on the fuel pressures. it should have 11-17 PSI to operate the injectors on a 87-94 TBI unit. I was thinking of the injection for CSFI & CPI Vortec engines fuel pressures.
Old Sep 19, 2019 | 8:38 PM
the aftermarket kits are the cheapest, easiest and smartest way to do this. or just buy a van with fi. Even if you had donor vehicle the work involved is significant.
I know the advantages of fi but don't get why go to all the work...do you need a project? tbi isn't much better than a carb.... so you'd be into multiport
Old Sep 19, 2019 | 8:55 PM
Or switch to a Holley carburetor. I had a hunch that OP's motor was factory with a Rochester Quadrajet, and I was correct. Worst carburetor ever built. Holley or Edlebrock would likely make a great difference.
Old Sep 19, 2019 | 9:08 PM
and it would be running in an hour
Old Dec 7, 2019 | 11:25 AM
Default Update
I was wondering about efi retrofit as it ran really rough and accelerated poorly, at the time a few months ago. But 2 months ago the water pump failed and while replacing the 4 v belts I noticed an empty pulley and saw it went for a.i.r. or smog pump, I bought and installed that belt and the power\acceleration issues I had were gone, and when doing a tune up saw my van got a remanufactured carburetor in '06 so all is well now.
RichardCaruso
Oct 24, 2017 11:32 AM
brock19890
Jul 30, 2012 10:04 AM
cherrycj7
Apr 5, 2010 10:43 PM
the angler
Jan 30, 2010 3:55 PM
