factory cruise control after the fact
Old Aug 16, 2020 | 5:01 PM
Edward Andriaccio's Avatar
Default factory cruise control after the fact
has anyone ever added cruise control after the fact,how easy,whats needed???
Old Aug 16, 2020 | 5:18 PM
I don't know what YOU need since you didn't provide any information about your vehicle.
Retrofit might be possible at home on older vehicles with cable controlled throttles.
GM have been using electronic throttles for almost 20 years now and cruise is programmed into the computer.
I'm guessing that:
- GM won't do it
- a well equipped shop MIGHT do it.
- it's not possible at home without expensive electronic equipment.
Old Aug 16, 2020 | 7:17 PM
2008 chevy express 2500 cargo,4.8.they sell the button and i know how to install it but is there other componets that would be needed to make it work?cruise control modulator?
Old Aug 16, 2020 | 7:28 PM
the same goes with the radio controls on steering wheel,they sell the button,.is it plug and play?is an extra harness needed,any help would be appreciated!!!
Old Aug 16, 2020 | 11:26 PM
do you have drive by wire or throttle cable? my 2000 sierra pu with throttle cable...all i needed was to get the cruise modulator assembly and multifunction switch. no programming required.
Old Aug 16, 2020 | 11:39 PM
Express vans were drive-by-wire from 2007
Old Aug 19, 2020 | 6:53 PM
has anyone successfully done this?
Old Aug 20, 2020 | 12:07 AM
Did you try web searching. There appears to be a ton of info. This is one of the first results:
https://diag.net/msg/m1qov9alg5paajbpypz4z0ycd5
Old Aug 20, 2020 | 1:48 PM
if its drive by wire...its all programming and a switch.
Old Aug 21, 2020 | 5:12 PM
William Kisselstein's Avatar
On vans like my 2002 2500 it depends on how it's equipped. My 3500 with crank windows and manual locks does not have the plug under hood for the cruise unit. My 2500 with power windows and locks does have the plug. I picked up a unit and a turn signal switch with cruise but I've never bothered to install it.
I see 2008 and newer with still crank windows and it makes me wonder if there's a difference, but if they're drive by wire then the computer already controls the throttle so likely you would just need the switch.
