G10 van stops running
Old Jun 8, 2019 | 8:51 AM
Rick Taylor's Avatar
Default G10 van stops running
Hello- I have a 1979 Chevy G10 with a rebuilt 1994 350 engine. It runs for 5 minutes then the fuel pressure drops to zero and it quits. I have tried running it with the gas cap off thinking it was a venting issue but no luck. Any ideas? Thanks Rick
Old Jun 8, 2019 | 9:21 AM
dberladyn's Avatar
fuel pump?
dirty fuel filter?
pinched fuel line?
carburetor issues?
Old Jun 8, 2019 | 9:45 AM
I read on another forum that the fuel filter can fill up with crud from the gas tank, have to replace my tank maybe?
Old Jun 8, 2019 | 3:20 PM
Irish_alley's Avatar
I'm here for the party
does it start right back up or does it have to sit for some time?
you said a 94 but did you keep the tbi or put a carb on it?
Old Jun 9, 2019 | 7:42 AM
I have a carb on it and a fuel pressure regulator running at 5.5 lbs of pressure. The pressure drops to zero as it starts to die. I have to wait about 15 minutes before it will start again. Also seems to quit mostly when going uphill.
Old Jun 9, 2019 | 9:32 AM
StanVan's Avatar
15 Year Member
Electric or mechanical fuel pump? If the pressure is dropping, it seems to me to be a fuel delivery issue.
Old Jun 9, 2019 | 6:07 PM
Electrical. I can't imagine it would run for a while than stop, but maybe?
Old Jun 10, 2019 | 9:57 AM
StanVan's Avatar
15 Year Member
It could if it's going bad.
Old Jun 14, 2019 | 8:09 PM
Any idea as to what I'm looking at here? Did not have this on my old engine. Thanks.
Old Jun 14, 2019 | 8:25 PM
thats a fuel pump filter and pump
