Heater problem
Old Dec 19, 2018 | 4:09 PM
Lucm's Avatar
Default Heater problem
I have a 2008 Chevy express 3500 6.0 that gives me uncontrollable heat or no heat at all. If I try to turn the heat off it keeps blasting full bore. Fan speed changes as it's supposed to, can switch from defrost to face to feet no problem there.
Turn the heat on while driving nothing happens, pull over and switch engine off and restart sometimes the heat will work.
Turn the temperature **** while driving no response. If it gets too hot sometimes I'll pull over turn everything off restart and it will stay off, to get the heat going again I have to pull over switch to high heat and restart engine and then I may get heat again. I'm thinking its vacuum related .
Any1 have any ideas?
Old Dec 19, 2018 | 4:30 PM
I think the temperature **** is electric and it controls the servo motor actuated blend door.
You should be able to find the schematics here: Search Wiring Diagrams
I would check voltages at the **** and the connector to the HVAC assembly. Also make sure the door is moving freely.
Old Dec 20, 2018 | 11:18 AM
William Kisselstein's Avatar
All those doors should be electric operated, although well after Chevy converted on the pickups the manual still contained reference to the old vacuum operated setup.
Old Dec 20, 2018 | 11:23 AM
dberladyn's Avatar
Have a look at the vacuum schematic. You can see the heater control valve there. This was just recently discussed in a prior thread.
Old Dec 20, 2018 | 11:50 AM
that diagram is for a 1999. OP has a 2008.
Old Dec 20, 2018 | 5:49 PM
dberladyn's Avatar
I am aware of that, I just suspect that GM didn't make many changes. If you find a newer one by all means please post it as I'd like to have one for my van.
Old Dec 20, 2018 | 6:29 PM
Look closer
This is a replacement part.
In auto, vacuum is used for things that need to be open or shut. How do you get vacuum to open something part way? The temperature dial is continuous.
Old Dec 28, 2018 | 10:51 PM
from GM ...
2005 GMC Truck Savana
Air Temperature Description and Operation
HVAC CONTROL COMPONENTS
Air Temperature Actuator The air temperature actuator and auxiliary air temperature actuator are a 3 wire bi-directional electric motor. Ignition 3 voltage, ground and control circuits enable the actuator to operate. The control circuit uses a 0-12 volt linear-ramped signal to command the actuator movement. The 0 and 12 volt control values represent the opposite limits of the actuator range of motion. The values in between 0 and 12 volts correspond to the positions between the limits.When the HVAC control assembly sets a commanded, or targeted, value, the control signal is set to a value between 0-12 volts. The actuator shaft rotates until the commanded position is reached. The module will maintain the control value until a new commanded value is needed.
