Help with Electrical Gremlins
Old Nov 19, 2025 | 2:26 PM
slagano's Avatar
Default Help with Electrical Gremlins
Hi - we need some help chasing down electrical gremlins. None of these work: power locks, blinkers, power windows, windshield wipers, hazards, radio (maybe more). Also battery voltage gauge on dash is not functioning.
Notification on dash showing "Battery Control Module needs service" - not sure if this is related.
Code reader shows only one code: "cam shaft position sensor". Replaced BCM and alternator. Good voltage from battery and alternator.
Any help, ideas, thoughts would be appreciated!!
(2014 Chevy Express)
Old Nov 19, 2025 | 7:59 PM
Triaged's Avatar
Alternator is computer controlled... that module. Need to get a better scan tool and solve that before throwing more parts at it.
https://charm.li/Chevrolet/2013/Expr...20Malfunction/
Old Dec 17, 2025 | 12:16 PM
redfm42's Avatar
I have a 2004 Express 3500 that has some wierd voltages on the gauge. Happened a week or two after changing alternator. I had the 105 amp but replaced it with the 145 amp and belt. Everything I have read says that the 2004 145 amp has an internal regulator and is just a higher capacity of the 105. Do you know if that is true or do I need to go back to the 105? Thank you.
Old Dec 17, 2025 | 12:36 PM
Triaged's Avatar
It's likely you have some other issue but just because an alternator is new doesn't mean it's good.
https://charm.li/Chevrolet/2004/Expr...d%20Operation/
I'd start by looking at the grounds, battery cables, and cable from the alternator to wherever it goes and look for voltage drop.
MitchM
Apr 22, 2025 9:19 AM
malibupaul
Mar 26, 2025 4:43 PM
Bkringeta
S10 & Blazer DIY and Useful Threads
May 21, 2018 5:42 AM
mma2012
Mar 1, 2017 11:13 PM
usassh
Jul 27, 2016 8:54 AM
