Help...need Photo
Old Jan 13, 2016 | 10:37 AM
hightechredneck1956's Avatar
Default Help...need Photo
Need photo of chevy express with composite headlights....I'm interested in the mounting points for the headlight unit onto the radiator core support..
I ordered an aftermarket radiator Core support and it doesn't have the little bracket where the lights clip on....
Can anyone out there help?
Old Jan 13, 2016 | 1:45 PM
Default done
even though the aftermarket parts come modified...they didn't include the cut-outs for the bottom light housing brackets.....I just cut slots being sure to leave enough lip for the bracket's end to catch....
DONE......onto chrome bumpers.
Old Jan 14, 2016 | 8:51 AM
Twscarp's Avatar
Here is my 2008 Express drivers side, your's looks a lot different.
Attached Thumbnails Help...need Photo-p1010177.jpg   Help...need Photo-p1010174.jpg   Help...need Photo-p1010176.jpg
Old Jan 14, 2016 | 8:59 AM
Default thanks but....
those are the top mounting holes....i need the bottom mount points.
but thanks for the effort
Old Jan 14, 2016 | 9:06 AM
Twscarp's Avatar
I can pull the light unit (two bolts) and take a pic if you need it...
Old Jan 14, 2016 | 9:12 AM
no....don't go thru all of that....
thanks anyway
Old Jan 17, 2016 | 7:04 PM
tsbrewers's Avatar
the bottoms hook in to the little tabs that you are pointing too.
look at this post, the pictures that have the little "X's", that is what needs to be cut out for the bottom brackets of the lights to latch on to. Then the top of the lights get screwed as show above,
https://chevroletforum.com/forum/exp...e2/#post208996
Old Jan 18, 2016 | 1:42 PM
Default Oem
I know how to make the aftermarket part work....I'm interested in seeing the GM part
