Interior Fusebox
Old Jul 7, 2019 | 1:15 PM
  #11
dberladyn's Avatar
Personally, I would avoid making the fusebox pivot, slide, or move in any way. That's just asking for broken wires. Great care was taken to stabilize wiring throughout the vehicle. The only places with movable wiring, the door harness, is where people experience the most electrical problems.
I won't promise.
I did just figure out how to add power lock switches to the side doors though. I want that. I was going to install them inside. I don't have the ability without the keys if I am using those doors.
Scratch that, switches still will not work without connected wires with the doors open. I just have to mount them on the pillars.
https://www.aliexpress.com/item/3295...4-013a04d7919e
Old Jul 7, 2019 | 1:18 PM
  #12
dberladyn's Avatar
Originally Posted by StanVan
How often would you need access to the fuse box? It would have to almost be daily to fatigue the wires. It's not like the wiring is solid core(as opposed to braided). Under the seat is a royal PITA. The one time I needed access, I felt the need to remove the seat, just so I could see. It is in a bad place, but I don't see an alternative.
I am going to do it and I am going to rebuild the fuse boxes.
https://www.aliexpress.com/item/3237...25e53c00u6wtnN
Old Jul 7, 2019 | 5:10 PM
  #13
In three years: never.
All the more reason to leave it alone. I'll make do with a mirror and flashlight.
Dan your van is NEVER going to be back together in one piece.
Old Jul 7, 2019 | 6:46 PM
  #14
dberladyn's Avatar
After three years of being railroaded in an out of the court/mental health system, I am think I am doing alright. I wouldn't wish I what I went through on anyone.
Thanks for the positive re-encouragement. In a few hours it could all be re-assembled. There is actually less panels off than yours. When you are continually waiting for a part, or changing your mind, it doesn't make sense to put it together.
Old Jul 7, 2019 | 7:22 PM
  #15
If I want you to go away then I will tell you want you want to hear. If I actually give two hoots about you, then you will get my honest opinion. This policy isn't always popular, but I would rather be known as trustworthy than popular.
You should find a happy place for all your audio doo-dads first. Leave the fusebox be for now. I know you'll do what you want anyway, and you should, but that's my two cents.
Old Jul 7, 2019 | 8:42 PM
  #16
dberladyn's Avatar
Anyways, I spent just under $40 today and I ordered the parts to lose circuit board of my latest radio. My fifth radio. When those come between 15 and 60 days from now, I can put the faceplate in, put the dash together and screw around all I want without opening the dash. So that is the route I am headed.
