Leaking coolant on passenger firewall , heater core hose,maybe Freeze plug ?or ?
Old Nov 20, 2021 | 2:20 PM
Trackvw's Avatar
Default Leaking coolant on passenger firewall , heater core hose,maybe Freeze plug ?or ?
Hi
My 2005 V8 van is leaking coolant from around the firewall area ?
Not sure if its heater hose or something else as I do not have a way to get under the van until I borrow a floor jack ,
But its dripping around the firewall area ,
If it is the heater hoses do I replace them from under the Van ?
Could it be a freeze plug ? Anything else that could leak coolant on the passenger side ?
Thanks for your help
Old Nov 20, 2021 | 4:25 PM
Do you have any photos? You can buy some UV leak trace dye to pinpoint the leak. Mostly likely heater hoses though. Replace from top.
Old Nov 20, 2021 | 5:59 PM
Trackvw's Avatar
Sorry no pictures yet , the coolant that is leaking has a green tint and the oil is not milky so its not a head gasket,
as a quick fix can I cut the heater core hose and put a bolt in it + clamp ?
I will look on youtube and see if there are any videos .
Thanks for your ideas
Old Nov 21, 2021 | 3:05 PM
Trackvw's Avatar
Hi....
I went to my buddy and used his floor jack......
It seems that the water pump is what is leaking , it is just dripping on the passenger side as it travels from the center of the water pump downstream,
or it looks like the center of the pump !
anyway now its time to get a new water pump installed ........any volunteers
Old Nov 21, 2021 | 4:17 PM
Trackvw's Avatar
So here is a nice pretty detailed Youtube video on replacing the water pump
any idea how many hours the book says it will take ?
Thanks
Old Nov 22, 2021 | 2:51 PM
Triaged's Avatar
It's likely time to replace all the rubber hoses too when you do the water pump. I'd do a least all the hoses that connect to the water pump. Get a set of cable pliers for the hose clamps. I used pliers for years not knowing what I was missing out on!
Something like these (I got whatever brand the local parts store was selling)
https://smile.amazon.com/Astro-Pneum...JF&srpt=PLIERS
Viking08
Sep 28, 2015 8:44 PM
hemifeverx
Apr 18, 2012 8:18 PM
gaftop1
Apr 8, 2012 12:33 PM
samger2
24
Nov 5, 2009 10:25 PM
twenty8
May 22, 2008 7:21 PM
