Little help please... No Headlights - G-30 VAN
Old Apr 18, 2011 | 12:19 PM
Voyageur's Avatar
Question Little help please... No Headlights - G-30 VAN
We own a Coachman Class C, motor-home, built on a Chevy full size van cab-chassis...
Last night I attempted to turn on the headlights and only had partial success. Tail lights and all running lights are on. Dash lights are on. "Blue" high-beam dash indicator light stays on. No daylight running lights. When I attempt to actuate the high/low beam actuator I get no typical "Click". While it may be the dimmer switch, are there are any other suggestions for items I should check first.
PS: Bulbs are good...
Thanks in advance.
David
Old Apr 18, 2011 | 12:20 PM
Voyageur's Avatar
Default Forgot to mention...
Our G-30 is a 1992 model (see previous post)...
Thanks
Old Apr 18, 2011 | 1:14 PM
BAGnDRAG-K5's Avatar
I would lean heavily towards the dimmer switch being out. This is a fairly simple fix tho. Yours is located on the column about 10-12 inches down from the steering wheel (towards the floor board). It has two small screws and a single wiring pigtail plug. Just make sure the position is correct on the installation or the unit may not engage the high beams correctly. If you need further help let me know.
Hope it helps.
Old Apr 18, 2011 | 1:17 PM
I also thought about something else, probably not this tho! Have you checked the relays? One of the could be out, however I doubt this is the case.
Hope it helps.
Old Apr 18, 2011 | 8:58 PM
RacerX's Avatar
did you check the headlight bulbs? they may be blown out. cheaper thing to look at first.
Old Apr 19, 2011 | 12:03 PM
He mentioned in the first box that he checked the bulbs and they are all good!
Old Apr 20, 2011 | 7:23 AM
RacerX's Avatar
how does he know? They dont work. Are they good or do they LOOK GOOD. Headlights are hard wired. They arent supposed to fail in any condition unless the bulb blows. If the blue headlight is on then the high beams should be on. He can put a voltmeter in the socket and check for current, on both the low and high beam in the twin system and on the white/red and green system in a single bulb system. He didnt say if he had twin or single. At least he will know if current is getting to the socket which I think it is.
Then he has to check the wires in the harness at the headlight. With some of these as I found out in my Suburban over time the plastic harness fails and the wires lose contact with the posts on the Headlight. Might need to fab a new headlight harness.
Old Sep 18, 2012 | 5:50 PM
RacerX's Avatar
he never came back and said what his problem was...
badass_llama
Camaro
Mar 25, 2009 10:37 AM
sonnys007
Mar 15, 2008 9:55 AM
jammons5126
Jan 18, 2008 3:44 PM
