Neither windows will operate. 1993 G30
Old August 29th, 2023, 3:18 PM
ll Mallow ll's Avatar
Arrow Neither windows will operate. 1993 G30
Hello,
1993 Chevy G30. Recently my driver and passenger side power windows won't operate. I've verified that power is getting to the switch and have replaced the switch. I'm wondering if anyone knows the wire path between windows. Does the ground for the drivers side window terminate at the passenger side? If the driver side window motor is completely dead, would that be the reason the passenger side is also not working because some sort of break in the chain? Assuming they are wired together to share the same fuse.
Any help/experience on this would be helpful.
Thanks!
Old August 29th, 2023, 4:32 PM
there should be a ground at each side.
Try testing the motors by applying 12V directly to them.
Common culprits are wires breaking in the door harness where they constantly bend back and forth.
johnt365
June 1st, 2020 10:00 PM
Betaform
June 14th, 2016 11:32 PM
biggun6ss
October 23rd, 2015 12:52 AM
LennyButch
December 1st, 2013 8:17 PM
rdome43417
December 26th, 2008 9:21 AM
Quick Reply: Neither windows will operate. 1993 G30
