no start
Old Feb 19, 2020 | 1:47 PM
garyj044's Avatar
Default no start
So i just drove 100 miles, then pulled into the my garage shut the van off then started it again was going to check the trans fluid, so when i get out the van died will not start. It ran great until then. No codes no warning Any ideas? Thank You
Old Feb 19, 2020 | 5:12 PM
loopedr1's Avatar
when you say no start..what do you mean..totally dead no dash lights.....lights but starter will not turn.....starter turns but it doesnt crank......starts but will not stay running.....
Old Feb 20, 2020 | 6:54 AM
Is the check engine light on? If so what are the codes?
Old Feb 20, 2020 | 1:33 PM
garyj044's Avatar
Engine spins great, no check engine light, it just died every thing seems fine, acts like no fuel
garyj044's Avatar
No Codes no check engine light
Old Feb 20, 2020 | 1:40 PM
astrolaab's Avatar
Fuelpump?
Old Feb 22, 2020 | 7:33 AM
ray caldwell's Avatar
Sounds like ignition module.. check for fire. If you got fire start testing the sensors 1 at a time. Oil pressure sensor can get clogged
Old Mar 23, 2020 | 11:50 AM
garyj044's Avatar
Got it fixed, fuel pump relay not making contact
Old Sep 16, 2020 | 5:34 PM
tireman9's Avatar
If you trace your problem to a bad relay you might want to review THIS post and consider filing a complaint with NHTSA (link in the post)
as this may be a defective part problem.
NHTSA can order a recall but there needs to be a number of complaints on file.
BallouBedquarters
Feb 27, 2025 4:19 PM
gamingglory
Jul 29, 2017 4:10 PM
Sabreman
Dec 21, 2016 11:56 AM
KimberlyHaltom
Jan 2, 2013 8:54 PM
shanael1
Apr 16, 2011 8:02 PM
