P1810 shifts out of park but doesn’t engage any gears.
Old Apr 28, 2024 | 12:01 PM
TSoc's Avatar
Default P1810 shifts out of park but doesn’t engage any gears.
2006 Chevy Express 2500 200,000 miles.
Awhile back I started to get an intermittent p1810 and it would start shifting rough. I shut it off for about 5 minutes and then it will shift out of park but won’t engage. If I unhook the battery it goes back to working great and shifting great.
It stopped happening all together for about 3,00-4,000 miles. Now it’s doing it again.
im thinking of replacing the ignition switch and seeing if that works as it seems like it must be a electric issue. If there was something broken in the transmission it would always be broken. Any ideas?
Old Apr 28, 2024 | 1:49 PM
Post your engine please.
not neccessarily. I think it's a transmission problem. Especially with your miles
Is there enough fluid in the trans?
Follow the troubleshooting steps here:
https://charm.li/Chevy%20Truck/2006/...0Transmission/
Old Apr 28, 2024 | 4:00 PM
TSoc's Avatar
it’s a 4.8 v8
fluid level is good
Old Feb 19, 2025 | 6:31 PM
fathead34's Avatar
Default I had the same problem
it’s a 4.8 v8
fluid level is good
I had the same issue. The door locks would also repeatedly lock and unlock very quickly and the abs light wouldcome on.. it was a loose negative battery terminal. Replaced the part that connects to battery and everything went away.
markpalus
Apr 28, 2024 4:13 PM
JPod
Jun 24, 2019 6:51 PM
kellen.humphrey
Jun 23, 2014 7:34 AM
dannyr424
May 29, 2014 1:00 PM
jimthesoundman
Jan 3, 2012 11:04 AM
