replacement tires - TPC SPEC
Old Feb 3, 2021 | 6:27 PM
tbb2's Avatar
15 Year Member
Default replacement tires - TPC SPEC
Van owner's manual qualifies new tires needing to meet a TPC SPEC (Tire Performance Criteria Specification) but does not say what that is.
Searching it seems the TPC spec is something specific to GM. Attempts at getting additional information just gets me funneled to a dealer.
I found one chart that refers to a TPC SPEC 1156 but nothing on what that entails.
I also found 'TPC Spec: 2012M6' stamped on a BRIDGESTONE; V-Steel RIB 265 that matches the size on my van.
Can someone shed some light on this TPC Spec and what good it is past the tire size and construction that are typical purchase requirements?
Old Feb 3, 2021 | 10:51 PM
is this something new? I thought you just follow the door jamb sticker.
Old Feb 4, 2021 | 11:00 AM
tbb2's Avatar
15 Year Member
I thought all that was important was the spec on the door too. I glanced in the owner's manual and read the TPC note.
I have no idea if TPCs are new or old. The van is 17 years old.
What does your owner's manual read?
If my experience is an indicator, what ever the TPC is it has changed due to age.
But I thought I would check. My assumptions cause me grief.
Old Feb 4, 2021 | 4:50 PM
My manual says:
This vehicle may come with all-season tires. These tires are designed to provide good overall performance on most road surfaces and weather conditions. Original equipment tires designed to GM's specific tire performance criteria have a TPC specification code molded onto the sidewall. Original equipment all-season tires can be identified by the last two characters of this TPC code, which will be “MS.”
Old Feb 4, 2021 | 5:07 PM
I dunno it sounds a bit like nonsense to me. GM vehicles aren't special or different from any other when it comes to tires.
Old Feb 4, 2021 | 5:13 PM
OK I read a bit more into it, and one particular tire model will get the contract to supply all new vehicles so it gets the stamp. It's stupid and you can ignore it.
Troberg
Jul 9, 2015 12:53 AM
Wigman
10
Aug 31, 2013 11:16 AM
jstchilln
May 22, 2012 1:25 PM
Dustin98ChevyBlazer
Jul 26, 2010 1:05 AM
cyras21
Jul 9, 2008 2:03 AM
