savana cranks /no start after sitting
Old Oct 31, 2024 | 1:59 AM
ncali's Avatar
Default savana cranks /no start after sitting
a friend of mine has a 2001 Savana 5.7 ls1 . When it sits after driving, it ill not start. It turns over like it is out of gas. give it a shot of carb cleaner and it starts right up and runs fine.
Any ideas as to why?
Old Oct 31, 2024 | 7:58 AM
zigblazer's Avatar
If it still has the old 5.7, it probably has the old spider style poppet injectors. Which are very sensitive to fuel pressure. When the fuel pump starts thinking of going bad, they refuse to start, but will run just fine once started.
Check fuel pressure on starting. Even being at the bottom end of spec can cause it not to start sometimes.
Old Oct 31, 2024 | 1:35 PM
ncali's Avatar
thank you for the reply,I will check the pressure
apoly
11
Mar 2, 2023 10:33 AM
clroby
Jun 21, 2012 6:25 PM
mtodd001
Aug 17, 2008 11:38 AM
davemec
Aug 7, 2007 11:50 PM
90burb
Apr 22, 2006 4:49 PM
