Shaking during acceleration
Old Jan 24, 2018 | 7:41 PM
Tranquildays's Avatar
Default Shaking during acceleration
My 2000 model Express is shaking, not only during accelerating but also when I put it in gear to drive. It has a new motor and spider injectors, new tires, I’m thinking maybe the U joint?
Old Jan 24, 2018 | 8:17 PM
canucklehead's Avatar
Yes, last time i had that issue (on my ford explorer), it was the u joint on the driveshaft......
Old Jan 24, 2018 | 8:23 PM
Thanks. I really know nothing about this, but was told that I shouldn’t drive it until it’s fixed.
Old Feb 1, 2018 | 2:59 PM
You mean when you're shifting and your foot is on the brake? That wouldn't be the U-joint. That sounds like a misfiring cylinder. Maybe there was a problem with the engine installation.
Old Feb 1, 2018 | 7:21 PM
jimmydriver's Avatar
Check your computer for codes. Check U-joints and carrier bearing if you have a split drive shaft.
Old Feb 2, 2018 | 5:52 AM
Thanks, so I took it to the mechanic, he thinks it’s the distributor cap.
Old Feb 2, 2018 | 2:27 PM
That wouldn't surprise me. It's a common problem with the pre-DIS Vortecs.
Old Feb 4, 2018 | 1:07 PM
My 88 G-20 shook like that. It was in fact the distributor cap. Arced like crazy inside. New cap, rotor, plugs, wires, fuel filter, vacuum lines. I can roast the tires now.
