Show us your mounts for Phone , Dashcam , GPS , clipboard , back up screen etc
Old Dec 23, 2019 | 11:42 AM
Trackvw's Avatar
Default Show us your mounts for Phone , Dashcam , GPS , clipboard , back up screen etc
Hi ,
I am looking for ideas to mount Phone , dashcam etc on my windshield or dashboard ,
how to mount them and also how to run all the power cords !
Its a 2005 base model van
I would love to see some of your ideas.....
Thanks for your help
Old Dec 24, 2019 | 12:33 AM
dberladyn's Avatar
I am actually driving around without a dash. I have had several configurations. Lately I am just using a mount that holds my phone horizontally above the heater controls. As for the front camera, mount it out of sight in front of the rear view mirror. I had a fancy tablet mount, but I kid you not, while I was sitting parked with the engine off, walking up to a morning cup of coffee, the metal just let go and whole assembly, including the tablet, just fell to the floor. I really liked that mount, but one bracket needed to be made of thicker steel. Eventually my truck will be much different when I get it reassembled again. I've been driving like this for months. Lack of money. I've really been sucking wind over the last year. I just started a new job today. If I stick with him, that should turn around quick and next year will be much better.
Old Jan 1, 2020 | 12:24 PM
tsoleno's Avatar
Ditto on sticking the cam behind the rear view. The cable will tuck nicely up under the headliner, run down the A pillar and under the dash. My cam uses a 12V cigarette type lighter adapter and can't be direct wired, so check your camera spec. My phone holder I bolted through one of the square knockouts down below next to the 12V receptacle. It stays low, out of sight yet is still easily usable when using a map program.
Old May 2, 2020 | 1:53 PM
john2000's Avatar
I added a 1" ball (RAM) to the dash overlay and really like this setup. It's stable and easy to position using the short extension between the ball and the phone holder. I run a 12" USB cable from my phone to a bluetooth FM transmitter that I plug into the driver's side 12v socket. (In case you're wondering, the switch below the 1" ball is for a Toguard camera which I just installed and like very much.)
Old May 2, 2020 | 9:15 PM
Black'95's Avatar
Veteran: Navy
I cut a block of wood from a 2x4 and sanded it down for a tight fit in the open slot cubbies on the dash of my 2018 Express. Next I covered the wood with sticky-back felt from the hobby store. Then I mounted a holder on the small one for my GPS and another holder on the large one for my iPad.
Old May 7, 2021 | 2:04 AM
Alice Hurry's Avatar
4. Smart Flask car cup holder adapter – For large mugs and bottles
  • Removable Ring ( For adjusting size )
  • Easily fit big flask bottles and mugs
  • The upper cup, mugs, the bottle is ( 3 1/8 inches deep ) for better hold
  • The other type of Bottles, Mugs, and Cups measuring ( 3 3/8 ) to ( 3 3 7/8 ) inches in diameter
  • It has 3 lids and one cup adapter ( Biteproof, Comfort, and travel lid )
  • The dimensions of the product are ( 4.25 x 4.25 x 6.12 ) inches: ( 5.61 Ounces )
It is the best car cup holder adapter for large cups and bottles, it provides Removable 3 rings to adjust the size of the base. we can say it is the best and adjustable car cup holder for large cups and bottles.
Three lids are also provided with the car cup holder, such as Travel lid, Comfort lid and Biteproof lid.
Travel lid: It is very safe and leakproof when you keep the bottle in the backpack while traveling.
Bite proof lid: The bit proof lid is made of hard plastic, So it doesn’t break with a light bite.
Comfort lid: It is more comfortable while drinking water.
Removable Sizing Ring – Adjustable base
It is called a Removable sizing ring (with a ring or without fitting ring ) car cup holder adapter, just like by adjusting the cup holder adapter in the car cup holder, It is OK if the cup holder fits into the car’s cup holder adapter with the Ring, otherwise, you can adjust the cup holder by removing the Ring.
for More Detail click here
https://www.caraccessories360.com/ca...or-large-cups/
Old May 7, 2021 | 5:18 AM
VinzClortho's Avatar
Default All exceptional ideas. TY
TY for sharing
bdemps77
2019+ Silverado (GMT-T1)
Aug 19, 2019 8:55 AM
rruelas
Aug 17, 2009 7:58 PM
mrsmoos
Dec 1, 2008 11:54 PM
Coppertop71
Feb 11, 2008 12:10 AM
pete_dallas
Feb 16, 2007 2:46 AM
