Solenoid B
Old Oct 15, 2015 | 4:57 PM
tbert's Avatar
Default Solenoid B
I'm having issues with my 1997 Chevy Express van. It shifts fine until I hit 3rd gear, and then it stays in third gear at every speed. I get a Solenoid B error on the ECU. If I clear the error code from the ECU, it will then go into the correct gear for 30 seconds or so, then revert back to 3rd when the error appears again. I've changed both A and B solenoids, the kick down solenoid, and the ignition switch which was what a transmission shop told me to change. I also replaced the trans harness. Still no luck. Does anyone have any ideas what could be the issue?
Here's the error code:
P0758: Shift Solenoid "B" Electrical
Mode $6 results:
TID:$02 CID:$04
- Lean to Rich sensor threshold voltage(constant)
Test incomplete or dependant test failed
TID:$02 CID:$10
TID:$02 CID:$11
TID:$02 CID:$12
TID:$02 CID:$16
TID:$02 CID:$20
TID:$02 CID:$21
TID:$02 CID:$26
TID:$02 CID:$30
TID:$02 CID:$31
TID:$02 CID:$36
TID:$02 CID:$40
TID:$02 CID:$46
TID:$04 CID:$20
- High sensor Voltage for switch time calculation
Max: 2,302
Test result value: 56,165
FAIL
TID:$04 CID:$30
Max: 2,302
Test result value: 62,728
FAIL
TID:$06 CID:$35
- Lean to Rich sensor switch time(calculated)
Max: 73
Test result value: 27
PASS
TID:$06 CID:$41
Max: 195
Test result value: 82
PASS
TID:$06 CID:$55
Max: 74
Test result value: 30
PASS
TID:$06 CID:$61
Max: 211
Test result value: 25
PASS
TID:$07 CID:$0c
- Minimum sensor Voltage for test cycle(calculated)
Max: 0
Test result value: 32,768
FAIL
TID:$07 CID:$0d
Max: 197
FAIL
Old Oct 15, 2015 | 11:35 PM
tbert's Avatar
Anyone have any suggestion?
Old Oct 16, 2015 | 10:47 PM
tbert's Avatar
Anyone?
Old Oct 17, 2015 | 10:20 PM
tbert's Avatar
I'm also getting lean bank errors after driving for quite a while (replaced 02 sensors). Not sure if that helps any or even makes a difference for the Solenoid errors. I used JET to reprogram back to original ECU program. Anyone have any ideas?
Old Oct 18, 2015 | 12:22 AM
canucklehead's Avatar
The tech data is out of my depth, but if you are getting lean bank after new o2 sensors, then maybe there are other sensor failures. Have you checked for other codes?
Have you had it scanned by a larger machine as in not a store bought handheld one?
Old Oct 18, 2015 | 1:19 PM
edac's Avatar
I'd just by this one, it runs great.
Express Hi Top van
Old Oct 19, 2015 | 10:29 PM
tbert's Avatar
Express Hi Top van
I would probably buy that one if you weren't a thousand miles away.
Old Oct 22, 2015 | 8:18 PM
edac's Avatar
Some one is supposed to pick it up Saturday, if it falls through I could meet you half way.
