Ticking type noise started
Old May 10, 2023 | 2:36 PM
Johnsond25's Avatar
Default Ticking type noise started
2016 express 2500 6.0
160k miles
no check engine lights
sound seems more pronounced on cold starts but never goes away, pretty sure I have a exhaust leak at the y pipe as well. Van runs fine, nothing seems out of normal operation.
any help is appreciated
File Type: mov
Old May 10, 2023 | 7:22 PM
oilcanhenry's Avatar
Yeah, sounds like an Exhaust leak to me.
Old May 10, 2023 | 9:02 PM
pomerlo's Avatar
If the ticking noise tends to fade as the engine warm up then yes it is typically an exhaust leak and more likely an exhaust manifold leak/crack.
As the metal expand with the heat then the gap that allow the air to leak is reduced in size.
Here is a video that can be useful to help you in finding the location of a leak:
Note: Never do this on a hot engine.
A smoke machine can also be used if you have acces to one.
Also here is one of the solutions in case you have a broken manifold bolt : https://www.dormanproducts.com/gsear...pair%2520Clamp
Good luck !
TEXAN1970
2014 - 2018 (GMT-K2)
Jan 14, 2022 10:53 AM
GBritt
Jul 5, 2021 1:15 PM
Metro
Jan 25, 2019 10:20 AM
pacmanz
Avalanche
11
Aug 10, 2013 2:19 AM
Roullette
Feb 20, 2010 12:54 PM
