Tow Hitch Wiring Plug - HELP
Old May 5, 2020 | 12:40 PM
Matthew Eberhart's Avatar
Default Tow Hitch Wiring Plug - HELP
I am trying to add a towing hitch to my 2019 Chevrolet Express 3500LT passenger van. I found this plug which is positioned at the rear bumper but I am unable to determine if this has to do with towing, or find a suitable adapter for standard towing plugs. Any assistance would be greatly appreciated.
Is this plug related to towing? Where can I find an adapter?
Old May 5, 2020 | 1:04 PM
Little Bear's Avatar
https://www.etrailer.com/t1-2019_Che...xpress+Van.htm Multiple choices here.
Old May 5, 2020 | 2:23 PM
Default Thanks, but doesn't match plug.
Originally Posted by Little Bear
Thank you Little Bear but none of those utilize the plug I posted in the picture.
Old May 5, 2020 | 3:10 PM
I would think then that this plug is not part of the tail lights/towing wiring. Looking at the adapters in the link if your truck did not have factory tow wiring then you need to go in and T off of each tail light assembly.
Old May 5, 2020 | 5:07 PM
kevinkpk's Avatar
Usually you have a round plug 7 pin. I would recommend you to U Haul for this.
Old Jan 3, 2021 | 4:12 PM
William Kisselstein's Avatar
OP's plug looks like it should plug into a piece similar to the Traverse unit shown, but probably an aftermarket of some sort. Got a you-pull or pick-a-part yard handy? Go out and start looking under bumpers, maybe you'll find the same one on another vehicle.
Advanex
Jun 10, 2021 7:09 PM
fomoco50
May 24, 2017 6:58 PM
kevin79
Aug 17, 2016 5:23 PM
jpatterson250
May 23, 2012 5:40 AM
SabrToothSqrl
Apr 2, 2009 7:14 PM
