Trans fluid in cooling system advice
Old Jan 27, 2023 | 11:10 PM
dogdayze's Avatar
Default Trans fluid in cooling system advice
I had a radiator blow and it mixed trans fluid and cooling fluid together. I have replaced the trans, the water pump and the radiator. Still finding some trans fluid in coolant after flushing about 5 times.
Has anyone had this happen? What was your experience? I’m now worried about the engine- whether the gaskets are now all ruined. Thanks for any advice.
Old Jan 28, 2023 | 2:04 AM
Old Jan 30, 2023 | 12:54 PM
its very hard to get it all out without a teardown. Water will wreck the clutch pack frictions discs. pan drop fill and flush is all you can do. If it starts slipping or hard shifting...its a rebuild.
bearbait
Mar 25, 2021 9:11 PM
Jwald
Jun 12, 2017 7:32 PM
Pugly
Jun 16, 2014 9:07 AM
bigr244
Jan 10, 2012 9:01 PM
Rob2002HD
Sep 7, 2007 7:05 PM
