Trouble starting my van
Old Dec 18, 2015 | 9:41 PM
Jeremie's Avatar
Default Trouble starting my van
I everybody,
I'm new to this forum and I'm looking for information on how to fix my van problem. (savana 2500 1999 5.0l)
The problem start 2 weeks ago as I was trying to start the van. The engine turn but it won't start. I tought that it was my battery even if almost new so I got another one under warrenty. I went back form the store and install it back and guess what it was not starting even if it had 12.6 volts. I put the charger on and few hours later I was able to start it. Problem is after one or two day (I don't use it much) I got to put the charger back in order to start the van even if the voltage of the battery is good. Once I have it running I can shut off the engine and restart it without any problem. I have check the alternator (got something like 14.3 volt) so I guess it not the problem. I look for parasitic drain nothing there neither. I don't know if someone have ever experience the same problem because right now I'm lost and I could use some help.
Thank,
Old Dec 19, 2015 | 2:10 AM
Are you saying it won't start at all or does it have to crank for about 10 seconds or so before it starts? If it starts after long cranking then you need to replace the fuel pump or add a check valve in the fuel line.
Old Dec 19, 2015 | 6:16 AM
Jeremie's Avatar
No it starting right away after charging for few hours. I also recently change the fuel filter as is was hard to start and I tought that was the problem.
Old Dec 19, 2015 | 5:03 PM
canucklehead's Avatar
Long cranking on cold starts could be the spark plugs are worn, or the gaps are too big. Also the dizzy cap gets corroded (oxidation) on each of the 8 pins on the underside, as does the tip of the rotor. Take off the dizzy and sand the points and clean them up. Weak spark makes for hard cold starts.
Old Dec 19, 2015 | 9:52 PM
Jeremie's Avatar
canucklehead I clean up the dizzy as there was some oxidation on the contact but I did not check the spark plug yet. I will look for that.
Thank,
Old Jan 27, 2016 | 4:16 AM
Jeremie's Avatar
Finally it turn out to be a weak fuel pump problem. The pressure from the pump was to low 30-35 psi.
Old Jan 27, 2016 | 9:36 AM
Thanks for posting the answer. Did you replace the pump and fuel filter?
Old Jan 27, 2016 | 11:35 AM
Jeremie's Avatar
The fuel filter was replace 1 month ago but the problem was still there. The van was towed to a garage at the beginning of the week for a diagnostic and they found the problem which was the weak fuel pump.
I like to post the result of a problem so it could help others peoples.
Old Feb 10, 2016 | 1:09 PM
Jeremie's Avatar
On top of it there was also a problem with the cap distributor. They change at the same time and now everything is working just fine.
Old Apr 14, 2016 | 9:42 PM
jr32560's Avatar
thanks so much for posting the cure--we need more of these type of posts so others know where and what to look for--kudos
